I'm sure this has been addressed in the past, but I've not had any luck searching for my answer.
We have a weekend/lake house in southern Iowa that I installed an air to air heat pump last spring. We don't winterize the house, so it's it's important we keep enough heat to keep the pipes from freezing, and I think it's probably betting to the new hardwood floors we installed. (We have a humidifier on the hp.)
My question is how should I run the temperature for the unit. Currently, I've been setting the thermostat to 50° when we leave and raising it when we arrive on the weekends. And at this time of the year, we may only use the house 1-2 weekends per month.
Knowing the hp will call for the backup electrical heat when I raise the t-stat more than 2°, am I kidding myself by keeping the heat low when we are not there? The installation company said we would be okay doing this, but another professional told me it would be cheaper overall just to set the t-stat at 65° and leave it. I don't remember the exact ratings on the system but I know the AC side is 16 seer and rated at 4 tons, and the resistance heat packs total 20kw. They told me the hp should function to around 10°.
In the depth of winter, we may see a few days of sub zero temps, but normally the lows are 10-20° and the highs are 20-30°.
So, let it run at 65 or keep setting it back to 50 when we aren't there?
