1 - 11 of 11 Posts
Not a gosh darn thing.
For example, in polyurethane, they take gloss poly and then add flattening agents to decrease the gloss.
They do something similar in flat paint. In a very simplistic way to describe it.
So, in other words, you wouldn't add anything to your paint, you would actually remove the flattening agents. That is if you could.
Reactions: Brass2312
Are ya' ready for this?. . .
What can I add to some Flat water-based paint, to make it Semi-gloss, or even Gloss?
Thanks, people.
Brass2312
Take some high gloss paint of the same type and color, mix it with the flat, and you will get something approaching semigloss.
· retired painter
I've intermixed different paints a lot over the yrs and found that it doesn't take a lot of flat to lessen the the sheen of the paint. You'd think that half flat and half gloss would give you semi-gloss but that mixture would be closer to satin.
Nothing really. You could increase the sheen by adding some acrylic resin, BUT the more you do that without adding pigment and/or flatting agents, the more transparent it becomes. It also would become thicker and need more water to be spreadable, thus diminishing hide even further.
There is a reason top shelf SG costs more than top shelf flat, it takes MORE resin AND higher quality pigment to get both sheen and hide.
Buy a can of semi-gloss. Use the flat for the first coat, and then the semi-gloss for the second coat. But make sure you get good coverage with the second coat, or you will be doing a third coat just to get an even surface.
Gloss to flat, a one way street.
Discussion Starter · #10 ·
Thanks very much for the replies, people.
KTownSkier: I Really like your signature line about "The only stupid question is the one you DON'T ask!"
Seems like this was already a fairly Stupid question. But, I asked anyway. Ah, well.
XSleeper: Dam, THAT's Brilliant! WHY didn't I think of it?! :vs_smirk:
JeffNC: Yup, I was being the cheap bastard that I am. Sounds like it can't really be done. :sad:
OK, Thanks, anyway, people.
I just added 1 gallon of semi-gloss to my 3 gallons of flat and it made it about a matte finish...which is exactly what I wanted. I opted for that option vs adding a straight gloss additive because I didn't want to change the color or consistency of the paint. (I know gloss is clear but just to be safe). Plus it was cheaper to buy a gallon of the same paint than to buy the amount of gloss I needed. Ya just got to mix very, very well and keep mixing as you go. I used a drill attachment mixing stick.
1 - 11 of 11 Posts
