I put new laminate on my bathroom vanity. The vanity was custom built in the late 60's This one is NOT a simple take one counter top off and replace with another. The counter top substrate 3/4 plywood actually holds the whole vanity together and is nailed to the studs on the wall.
So here is my question, i want to reuse or even replace the substrate that was used as a backsplash. (1x4) It appears back in the day they used to nail the backspalsh to the wall then laminate it. Well if i do that i cant trim the laminate cause my compact router is wider than the board that is being used as a back splash.
So how do i finish the back splash after it is attached to the wall so i can trim it. Of course the wall is not straight so i need to scribe it. it is 3/4 inch wide on top.
Thanks
Thanks
