I have a Trane gas furnace with a air-conditioning combination unit.
The Trane gas furnace model is TDD140R960C5 around 8 years old. The furnace Controller is White Roger Emerson, Model 50A51-495. Yesterday, the furnace stopped working. I tested the furnace. I found after the thermostat turned on the furnace, the controller clicked a sequences and the glow igniter device turned on three times. The small blower at the exhaust turned on. However, the gas valve was not turned on. At the end of the sequence the blower turn on, but was blowing un-heated air. I noticed the controller LED did not blink any special sequence, just normal slow flashing. I test my gas water heater, sitting next to the furnace and the heater worked fine. Today, the furnace is working again.
I suggest suspect the valve is intermittent. Can you please tell me, according to my picture:
What kind of gas valve I have? I assume this is the unit labeled “R”. How to test if this valve is faulty, online?
What is the function of this small fan at the exhaust?
What is this two round metal cans, labeled “P02 Low” and P01 HI”?
