1 - 9 of 9 Posts
· In Loving Memory
Even though its on an inside wall, still could be a draft in the wall. As they had to drill a hole in the plate to get the thermostat wire up to the thermostat.
Could just be the thermostat isn't accurate.
Some thermostats can be offset to match the house temp, check your owners manual.
I would think a draft of cold air from anywhere to the stat would normally make the stat read lower than actual room temperature rather than higher. Also the accuracy of thermometers in the price range we deal with aren't always that great. If there was a 2° + : - accuracy in manufacturer that differential is easily obtained.
· In Loving Memory
Not all drafts are cold air drafts.
Could even be a supply run to the upper floor is in that stud bay.
1 - 9 of 9 Posts
