How to Support Bench After Removing Rail
653 Views 4 Replies 3 Participants Last post by  carpdad
I have a bench that I would like to gain more underneath storage space from. My thought is to remove the front horizontal support rail (in order to easily access baskets that would slide underneath). What is the best (non-visible) way to support the bench after the piece is removed? (Photo attached)
Why ruin a fine old piece like that?
move it to another room, and replace it with a modern piece of furniture that is not as valuable, then build a base underneath the new one.
ED
Reactions: 2
ED
It's old and does have sentimental value, so I want to find a way to make it work. There is absolutely no other place to put it in our house, otherwise I'd just build a built-in.
I would still find it a new space somewhere, and build that built-in.
It is too ornate and in such great shape, it seems sinful to cut it up.
ED
Reactions: 2
If you can disfigure it, then the value is minor. Then sell it and buy the piece you want and need. Here in NJ, $500 would be throw away price and I'd think 1-2000 is very affordable. Did you appraise it? These are total guesses and I am rather cheap.:smile: Do you want to put boots under it? Store them flat. It is a kind of furniture that can't be replaced, and shame to destroy it.
If you must, how is the leg attached to the seat's frame? It looks like the leg was designed for lightness and the attachment point would not be robust. The rails are structural and if you remove it, and the seat is used often, the attachment will become loose quickly. There is no invisible way to reinforce the attachment. Somekind of brace is needed, which means metal angle or wood triangle. Screws will have to be used, and screws become loose.
