We have an RV sub panel at the rear of our house to connect our RV. The sub panel contains 50A/30A/20 Amp breakers. The breaker on the master panel feeding the sub panel is 60A.
The 20A breaker in the RV sub panel has 3 things connected: (1) a small gate operator via conduit, (2) a small underground sump pump connected to city waste water to dispense RV waste, (3) a single outlet in a nearby small 10’x12’ shed. The shed outlet is connected via conduit underground with 3 separate wires (THHN or similar). All were permitted and installed by a master electrician, inspected and approved.
Now wanting to install in the shed a 110V switched inside LED light (only 7 watts) and two outside shed LED lights (about the same), plus an additional outlet for a very small A/C heat pump which draws about 8A max.
Is there a code compliant way to install a small breaker for the light circuit to allow 14 gauge lighting circuit and switch, from the incoming 12 gauge wire, without upgrading the wire in the conduit or downgrading the 20A breaker in the RV panel?
Cannot see a sub panel available which would support 12 gauge lugs and a 15A breaker for a lighting circuit. My load requirements are minimal – just the small heat pump plugged in to the outlet and the shed lights.
Have considered using a blank face GFCI or AFCI for the lighting circuit but they seem to be 20A not 15 and not really suitable as a separate circuit.
Would like to rely on the 20A breaker in the RV sub panel to control everything but still reduce the lighting circuit with a single breaker if that is allowed.
Thanks
Thanks
