1 - 7 of 7 Posts
bought a fairly antique 20" Monarch bandsaw. It came with a gigantic (~16" diameter) 5HP electric motor. I'm not sure a bandsaw of this size needs this much motor, but since I have it, I'll try to use it.
The motor appears to be 5HP 3Phase, and probably 1730RPM. It is old enough that I can't find information about it on the 'net. In the US, power is supplied to residences in single phase, so I would like to size and buy an appropriate VFD/Inverter/starter to run it from 240VAC 1-phase at 220VAC 3-phase. It would be great to choose the run speed, have soft start so there's not a huge inrush current, and possibly use dynamic braking.
I've seen less expensive Chinese manufactured VFD's on ebay, but there's typically no consultation with the vendors, and caveat emptor. I have seen recommendations for sizing at multiples of up to 6 or 8 times Full Load Amps. Also I've seen it said with 1 to 2 HP motors that 2 x FLA is sufficient. The label is faded enough that I can't be sure about the listed FLA (12? 12.68? 12/6.8 at 220/440?) nor the motor efficiency.
645121
One formula I found online shows to use ((HP x 746watts/HP) ÷ Efficiency) x √3(for 3phase) to get the KW required to size the VFD properly. It sounds right, but I can't read the necessary info from the motor badge so I wondered if anyone is familiar with this gear enough to make a recommendation?
Thanks
Antique GE Induction Motor, 5HP - 3PH - 220VAC
Table 430.250 will give a typical full load current of a 3 phase 230 volt motor as 15.2 amps. Then multiple 15.2 x 1.73= 26.3 amps. Look for a VFD in the 5 hp rating that has a single phase input of at least 26.3 amps. They make them just for what you are trying to do.
Those nameplates have the legends embossed, and the entered numbers punched in. So they are meant to be readable even if painted over (evenly).
I don't see on the nameplate where you think the motor has any 440V ability. Some motors provide a set of jumpers you can move around (dual fields that can be wired in series or parallel) but not every motor.
The OP was 7 months ago, so he's probably long gone, but-
I highly doubt a motor of that vintage is inverter rated.
It would probably have a very short lived life on a VFD.
Actually still around. I've learned a lot since posting. The name-plate shows amps as "12 6.8" so it was natural to wonder if it may have a dual voltage intent that was mismarked or else omitted. I found no specific info about this motor.
That's illuminating, thanks. Another approach I found gives a close result:
~746 watts/hp x 5 hp == 3730 watts.
Uprate by (~√3) △ 3730W x 1.73(factor) == 6460
Test: (W ÷ V == A) 6460W ÷ 240V == 26.9A.
This motor is absolutely not inverter rated. It might be possible to use it safely with proper load reactance, but I don't have a recipe for that.
Anyone?
Unless you are going to run it at half speed under high torque, don’t worry. In almost 40 years and hundreds of VFDs I’ve been involved with, I have seen only one motor that was made specifically for a VFD. None of the rest had any problems. My experience spans small hp motors to large several hundred hp motors. VFDs half the size of a loaf of bread to VFDs larger than three phone booths.
1 - 7 of 7 Posts
