Hi, I'd like to build a temporary wall with a door, over tile floor, in order to essentially create an attached guest house in our home by sealing off one room from the rest of the home, but will still have it's own bathroom and entrance from the side door already there. I say temporary wall because we will eventually want to take it down either in 6mos to a year, if/when we sell the home or whatnot, so dont want alot of damage. With that said, I will of course attach the studs to the ceiling joist and current wall studs, but as far as the bottom plate, I didnt want to drill through the tile so was contemplating using very strong double sided tape to keep the bottom plate in place on the tile. Does that sound like it would hold, considering there will be a door it must support? Not sure how tape would stick to tile long term with potential moisture considerations? How long do you expect to hold? Any tape recommendations -brands, foam backed or not, etc?
I was considering a strong glue but didnt want to deal with a potentially difficult time removing the glue later. Tape just sounded so much easier.
I understand I could potentially drill some parts of the bottom plate through the grout in the title, but am aiming for least amount of damage / work possible that was enough to get the job done.
Any other potential solutions?
Thanks in advance for responding.
