I bought two 1 1/2 inch PVC shutoff valves from Ace, to plumb a hot tub. I glued them in place with the new type Gorilla Glue, no primmer or cleaner needed, they say. All went well yesterday, today both of the shutoff valves are leaking dead center on the bottom of the valve, they are both defective.
One shutoff valve is in a really hard to get to place and will take me hours to change out. The bad thing is that PVC fittings is glued into the one that is screwed directly into the pump. That fitting can not be bought at any hardware store as it is a special fitting that came with the pump.
It will take a week or so for the new fitting to get here. I have seen on youtube that PVC pipe can be removed from a fitting with heat and a pair of pliers.
Have any of you ever tried that, will it damage the fitting?
