I googled and gave up. :sad: I need to lift an entire 2-axle, 18ft, 2300 lbs cargo trailer for at least 12" to slide under to do some work.
How can I do that properly and safely (without being killed too much
Obviously I don't have access to garage / shop lift.
I though about putting two 4'x4'x8 wooden posts under trailer's belly (one 4 ft from front / end of the trailer) and jack them up on both sides, later securing the trailer with additional jack stands (four - 1 at each frame corner). Is this a good idea?
Perhaps you can think about another trick?
Thank you,
J.
Thank you,
J.
