I apologize if this is too long or too much information but I thought it would make more sense if I made everything as clear as possible. Thank you for your patience.
End of last summer my condenser fan motor went bad (fan did not spin and loud squealing noise) on my AC unit. I purchased a universal Emerson motor online to replace the bad condenser fan motor. After a lot of research I am still not comfortable installing the motor myself. Here are some of my high level concerns and questions. Any assistance would be greatly appreciated.
1. Proper Wiring: My old fan motor has three wires - black, purple and brown. The new fan motor has 4 (excluding the 4 wires used for fan rotation) - black, white, brown and brown/white stripe. QUESTION 1: Based on the information below (technical details) what would my new wiring configuration look like? I am having trouble determining the new wiring setup based on the 4 wire set out of the new motor and the new capacitor.
2. Capacitor: I was going to use the old capacitor. I emailed Emerson to see if I could use the old and they told me that I need to use the new capacitor that shipped with the motor. This adds complexity to the install since the old capacitor has 3 heads (one head with 1 pin, second head with 3 pins and forth with 4 pins) and the new capacitor has 2 heads with 4 pins each. QUESTION 2: Similar to question 1, should I use the new capacitor and what wires should go to each pin (see info below on current motor wiring and wiring to capacitor)?
3. Discharge of the old capacitor. I plan to turn the power off to both the unit and the house but I don't want to get shocked by the capacitor. I need information on the proper way to discharge the capacitor. QUESTION 3: How can I easily discharge the power from the capacitor? I currently don't have any specific tools for electrical work (meters, testers, etc).
NOTE: See pictures that go along with this narrative - current unit, wiring setup, wiring diagram, motor and new motor, new motor wiring diagram, etc.. I can attach more if needed.
EXISITING SYSTEM:
1. AC Unit - Goodman (Model CKJ48-1B, Serial, 9704113098).
2. Old Motor (broken): GE - Here are the specs. from the label on the motor.
MODEL 5KCP39EG R808AS HP - 1/4
VOLT - 208-230
RPM 1075
HZ - 60
AMP - 1.5
THERMALLY PROTECTED
CL B INS-CONT AIR OVER
3. Existing Capacitor
97F9895
5uf
45uf 370VAC
+06 -06% 50/60Hz
PRTECTED P968
S10000AFC 7143GB02
B94557-7200 / GREEN
4. Existing wiring:
My existing motor only has three wires and is connected this way.
Black -> T1
Brown -> F (on the capacitor)
Purple -> C (on the capacitor)
Current wiring to capacitor (NOTE: current capacitor has 3 heads - one head with 1 pin, second head with 3 pins and third head with 1 pin. The new capacitor only has 2 heads with 4 pins each)
Head 1 on current cap. - only one wire - brown (coming from motor - label "F" on cap) ]
Head 2 on current cap. - purple (coming from motor to "C" on cap.), red (going to starter assistant device to "C" on cap), red (coming
from T2 to "C" on cap).
Head 3 on current cap - yellow (compressor to "HERM" on cap.), orange (starter assistant device to "HERM" on cap.)
Existing wiring schematic for AC Unit:
NEW MOTOR AND CAPACITOR INFO:
New Capacitor (two heads, four pins / head):
5.0uF +6%(H) 440VAC/B
SH P2 CAPACITOR EIA-456-A
50/60Hz -40 degrees C / 70 degrees C
INTERNALLY PROTECTED 10000 AFC
New Motor: Emerson - Here are the specs. from the label on the motor.
MODEL K55HXWMS-1280 HP 1/4
VOLT - 208-230
R.P.M - 1075
HZ - 60
AMP 1.5
THERMALLY PROTECTED AUTO
INS CL B 60 degree C AMB MFG. NO. E10 C
AIR OVER CONT CAT NO. 1860 FRAME 48Y
Wiring diagram for new motor:
Note: This diagram excludes the four wires used for fan rotation (orange and yellow wires).
Four Wire Connection:
---------------------White-------------------------------L2
I
208-230 Volt Line
I
--------------------Black--------------------------------L1
------------------- Brown -------------------------------
I
5.0 MFD 370V CAP
T
-----------------Brown/White Stripe -----------------
OPTIONAL 3 WIRE
CONNECTION
BRW/WHT STRIPE-INSULATE
CAP.
Brown -------------O
White--------------O----------L2
Black- L1
I would greatly appreciate any advise you could provide...thank you in advance. :thumbsup:
EXISITING SYSTEM:
VOLT - 208-230
RPM 1075
HZ - 60
AMP - 1.5
THERMALLY PROTECTED
97F9895
5uf
45uf 370VAC
+06 -06% 50/60Hz
PRTECTED P968
S10000AFC 7143GB02
B94557-7200 / GREEN
4. Existing wiring:
Black -> T1
VOLT - 208-230
R.P.M - 1075
HZ - 60
AMP 1.5
I
208-230 Volt Line
I
I
5.0 MFD 370V CAP
T
OPTIONAL 3 WIRE
CONNECTION
CAP.
Black- L1
