Hello all, I am trying to replace my old cast iron drain pipes in my basement. I have about 3 feet of cast iron to replace with 3 inch ABS piping. My cast iron goes all the way up to toilet flange. I plan on replacing the toilet as well. The rest of my drain pipes are 3 inch ABS into the basement concrete floor. The current ABS goes from concrete floor up to about where the joists are for the basement ceiling. There is a rubber coupling to connect the ABS to the Cast iron. I plan on removing all the cast iron and replacing it with 3 inch ABS piping. I believe I would need a 90 degree elbow, sanitary TEE, and about 3 feet of straight ABS piping. Obviously, glued together with proper glue. My cast iron looks to be either 3 or 4 inch cast iron. Not sure about how to do this. The top of cast iron below the toilet flange looks like 4 inch, then narrows to 3 inch. Also, why does the pipe go straight up from the main stack? Is that the vent for the waste pipe up through the roof? I will attach pictures so you can see what I mean. There looks to be a newer sub floor below the toilet and around the toilet flange. I guess the original home owner replaced the toilet about 10 years ago and put a cast iron adapter for the flange on the cast iron drain pipe. Let me know what you think needs to be done with this. Thanks, Jeff
