I'll start off by stating I live in Central Texas - so that you can think about what type of weather we have here: We have about 19 sub-freezing day in the winter; about 90-100 days, low 90s to low 100s in the summer, and an average of 79 rain days a year with an average about 13 inches of rain each year, with May and June having 5 and 4 inches, respectively.
I had racoons get into my attic and they made their way to the space between the 1st and 2nd floor by climbing down the shaft for the AC flex duct running from the 2nd story to the 1st.
The space is about 16 inches (top to bottom), created by the pre-manufactured trusses they used to create the ceiling of the 1st story (level) and the floor of the 2nd story (level). I haven't for the life of me been able to find what this space is called.
In this space they damaged alot of AC duct, electrical cabling jackets and, from I can tell, they were trying to find a way out and knocked down or tore up almost all the insulation in the exterior walls AND (this is related directly to my question) the asphalt paper that was used to wrap the house.
I had to have the sheetrock ceiling for the 1st story removed to get to this area to fix the electric. With the sheetrock down it makes it easier to replace the AC flexduct.
I need to make sure that the asphalt paper in the exterior wall is fixed the right way. I had 3 contractors come by and each gave me a different method (and price) to fix the damage to the asphalt paper. Since none of them (separately, without me telling them what the other said) were in agreement on how it should be fixed, I did my own research, but cannot find much on this - other than to fix it 'the right way' 'from the outside'. But tearing down the exterior brick walls (3 sides) and fiber-cement siding (back side) to replace the asphalt paper (approximate 16 inches tall x 22 inches wide) (spaces between the trusses) seems very excessive to me, not to mention it would be very costly.
As already stated, I live in Central Texas, and not sure why asphalt paper is used in homes here, is it for the rain, or the wind, or both? If it's just for the wind, seems like cutting squares to put in the spaces, secure it with staples and then insulate behind it will do the trick. If it is for rain, then that solution will not work.
Anyone have a similar experience, or advice to share? And how was it fixed?
One photo attached, with some damage to asphalt paper, but in almost all the other areas, the asphalt paper was torn off from stud to stud (side to side, top to bottom).
Thank you in advance for your review and replies.
