1 - 9 of 9 Posts
Hi!
How do you go about removing the handle on the faucet in this picture?
Uploaded with ImageShack.us
One would think the little caps on the handles would pop off, but they didn't. I just used my fingernail and it's like they couldn't lift off. I didn't want to try a screwdriver before checking here to see if anybody has any hints.
Thanks!
Thank you for the responses.
I saw that web site and tried 4a, but it didn't work. The only part that rotates is the handle part. The area below the handle doesn't rotate.
I would think it would be a cap on the handle, but I didn't want to gouge or scratch the handle if it won't work.
I'm open to other ideas!!
Thanks!
You may need to apply a bit of force to get the lower part to move; it may be stuck with corrosion, deposits, etc...Try one of those rubber jar openers or something that won't scratch the lower part (rotate ccw).
i checked the link after i posted the last one. they had just come out with that handle style just before i got out of plumbing. got tired of it after 20 years. like bob said it might be kinda tight fro, corrosion
Discussion Starter · #8 ·
Thank you all for the responses.
When I got home today, I used a rubber strap wrench and was able to rotate the area right under the handle in order to remove it, just like everybody mentioned. I didn't scratch anything and it worked out great.
Thanks for the help!!
1 - 9 of 9 Posts
