1 - 20 of 45 Posts
Hi
We're in the midst of renovating our new house and lots of walls have been changed and/or need to be repainted.
We have 12 rooms to paint walls and ceiling. 3 rooms are only plaster.
What is the fastest way to do that?
We've done roller and brush painting before, but we were wondering if it would be faster to get a sprayer because of the shear volume?
If so, how much time would it save (10%? 20%?) and what sprayer and equipment do we need?
Thanks in advance :)
sounds a lot like me as well ive been working on a 2500 sq house bye myself with little to no exp not fun at all lol not sure how many walls too many of them and i dont want to go into panic mood which ill do if i count all of them lol. but to answer your questin? i use a roller myself but its been taking a long timee to finish everything.kind of wish i would have tried a sprayer instead now.
· Rubbin walls since'79
Hey, despite popular opinion- this painting thing isn't easy. Takes some skills and practice.
If you don't have that- patience. If you hurry it- it will screw up. Really.
· NACE Coating Inspector
spraying is normally much faster than a brush and a roller if you are doing large enough areas of a single color. i went through 4-6 55gal drums of paint on bridges with one other guy in a 12 hour shift several times. i cant see that happening with a brush. i dont think that 12 rooms/ interior justifies using a sprayer. just the time and money spent masking off the windows alone would be a deciding factor for me. im not a big fan of spraying inside due to the amount of clean up involved also. i have sprayed and back brushed trim and door casing to speed things up a little. quality paint and tools will help speed up progress too. having to add an extra coat because you went cheap on paint will slow things down for sure.
· Retired Moderator
Spraying the ceiling with someone back rolling to add orange peal--then spray the trim and doors--
hand cut the walls and roll----
That will speed things up and not make to big of a mess if you don't have any floor coverings.
Airless paint pump is the tool---rent a good one--they are to expensive for one job and the cheap ones just won't do the job.
Often all the masking involved makes spraying inside a waste of time.----Mike----
· Learning by Doing
How to paint a whole house very quickly?
Hire someone who knows what they are doing to do it.
Whenever I can afford it, I hire someone else to do it. Pros can do it WAY faster and produce great results.
How to learn to be a decent painter?
Paint 12 rooms in your house.
I really like painting. I like the prep and I love the joy of finishing. I'm getting steadily better results, and learning how to work faster.
I'm the sort of DIYer who finds sublime joy in approaching a new discipline, gaining competence and finally, skill while I tackle jobs around my home. My first paint jobs aren't nearly as good as my most recent. But, I'm about ready for a change now... and since I know my prep was STERLING, it will be easy to re-coat.
I have a high quality sprayer that my sweet, misguided, husband bought me. I ONLY use it for projects that can be done outside. Works like a champ. Used it once on my house to paint the underside of a porch roof. It took so much time to mask off the windows, doors, floor, etc, that it would have been faster just to roll it.
And the skill required to do a good job of spraying on paint takes time to develop the skill.
· Premium Member
In my opinion, a pro with a roller and brush can paint twice as fast as a DIYer with a sprayer...........I'm saying that to point out that spraying is really not the time-saver everyone thinks it is. Prep, masking, color changeovers, clean up, all take major amounts of time when spraying. Yes, there is some of that with rolling, but, in the end I believe the brush and roller do a superior job in the most efficient amount of time.
well seems everyone covered the sprayer vs cut/roll pretty well..but i will add this..
dont let the amount of painting over whelm you.. break it into sections..
ceilings-all the same color
trim - all the same color
walls - varying colors..
do each section until completion, clean up and prep for the next section.. this way you wont hav eto wash out your tools for every color change in every room and
DONT FORGET TO BOX YOUR COLORED PAINT!
· Retired Moderator
OOPS!!!!
Boxing; Mixing all the cans of paint together in a big bucket---the mixing machines are not perfect and some times one gallon will have a slightly different color or sheen.
Discussion Starter · #17 ·
Thanks very much for all your thoughts. Because some rooms are plaster we'll probably need 3 coats and because the other rooms have been painted dark colours we'll need 2, so really we'll be painting the equivalent of about 26 rooms.
If spraying is much harder and doesn't save much time because of the taping that's fine :)
Just was hoping to save a bit of time as I've had to learn the electrics and joinery so far and that's taken 2 months.
Brushes and rollers it is :)
Thanks again.
if you want to save some time spray the closets and ceilings.. not much you can screw up there ( unless you have finished floors already in) and minimal prep as you just need to avoid the light fixtures and you can spray on the ceiling/wall joint as your cutting that in w a brush anyway. they are pretty fun to do in my opinion:yes:
One thing that helps move things along is using the bigger roller covers.
The typical size is 9" , there is also 12, 14 and 18" . I like the 14, not too big and heavy, and can get most places. But you need a special frame and bucket to use it.
Wooster makes the whole set up, and I think Purty has it too. Might have to buy online.
if you are gonna go with a the larger roller cover get a quality frame.. i only use a 9 or an 18.. so i can only speak from my experience but there is NOTHING WORSE then messing with a crappy frame like this...
when big ben will never let you down
1 - 20 of 45 Posts
