I have a bran new multi-voltage barrel plug type power adapter that is rated for 12 volts and 36 watts.
My device requires 12 volts, 3amps with center pin negative polarity.
When I select the 12 volt setting, along with the negative polarity adapter and plug it into my device, the device control panel is acting as if it is not receiving enough power to fully operate, some of the the lights blink on and off in a pattern but the main LED never lights up.
I believe I may not be getting sufficient current to the device out of this power adapter. How can I check how many amps the power adapter is supplying to my device? I have a multimeter with an 10amp input terminal.
Here is the new adapter I'm trying to use. I have it set to the 12 volt setting and have the negative polarity adapter attached along with the 5.5x2.1mm barrel plug.
