Appreciate any help the group can lend.
- I would like to know specifics about the plugs used when blowing insulation into walls from the outside. Are the plugs the same size as the hole, if so how do you secure it from falling in? Are they made out of plywood? how think should they be? Do they have a cone shape?
- Understand the blowers used for attics are not powerful enough for tight packing needed for walls (2.9psi). Is it easy to rent the types of blowers required?
Thanks for responding,
K
