I need some advice on how to level the 2 areas of my house that are next to each other.
One room used to be a garage converted by the last owner (poorly):plain:
The other area is the entry-way that was covered by flooring I removed... and SURPRISE concrete SLAB?:vs_worry:
So now... the concrete slab in my entry is higher then the garage conversion floor. I would like the floor to be the same level and I really want to be able to add a sink in the garage conversion room and insulate the floor (because it's damn cold!)
There will be more pics and I hope they help explain the situation better
Discussion Starter #3
Whats going down on the floor in the garage conversion?
How much of a delta?
So everything worked out I just removed it all. Put down some gravel and poured the floor through the front window.
Progress attached.
Thanks.
