I'm going to put wooden windowsills here. How do I level the surface in preparation?
That is true. Assuming you find it is level...Make sure the window is level first. If its not and you level the window sill, it might be noticeable right away. It depends on how much.
Like this? (Except using a combination square instead of this)?Put a combination square on the wall and use shims. Or use a torpedo level.
Adhering the Poplar window stool to the CMU block. Is tapcons overkill? I wouldn't want to risk damaging this expensive wood.Your question about adhering wood to block is top vague to answer. Tapcons.
