Nope, actually I'll post a pic of the area. Let me know how you would arrange them. In the pic you will see square stones around the patio in the mulch. I'm going to take those out and use those and add some more if needed. I was thinking about spacing them out a bit further like 2 ft apart...is that too far apart?Dig out for them and inset them flush with the surface of the fill. You can mow right over them.
Was this a trick question?![]()
Stretch out a tape measure on the ground. Then walk normally beside it and note the average length of your stride. THAT is where you would place/space/center the stones.is that too far apart?
something like this for example?Stretch out a tape measure on the ground. Then walk normally beside it and note the average length of your stride. THAT is where you would place/space/center the stones.
Are you sure these aren't trick questions?![]()
Gee thx...Bud Cline said:Yup something like that, okay I'm out of here.![]()
Thx alot!kwikfishron said:17-18” is a comfortable step for most humans.
Just lay them out on the ground and adjust until you’re comfortable with them, then brake out the shovel.
Is it wise to pour some sand under the stones?kwikfishron said:17-18” is a comfortable step for most humans.
I already have some.kwikfishron said:You certainly can, the sand will make it easier to get a flat base. If I was just laying a few in my yard I don’t know that I’d go buy any sand though.
