I have a shed that we are going to run power out to. Eventually we want to put a couple of flood lights on top of the shed to give light to our pool. The problem is that the shed is a bit too short. I need to get the floods about 1 ½ - 2’ higher. I was going to use PVC conduit. I was thinking of extending the pipe above the shed but I believe PVC cannot support conduit bodies or light fixtures?? Is EMT OK? Strong enough? Will it need its own ground rod? The shed is 15' from the pool.
I’m looking for some ideas. Thank you.
