1 - 10 of 10 Posts
Looking to probably build an arbor above our garage doors but cannot figure how to attach it to the actual house. Should I expect to cut out part of the vinyl? Or hang on the vinyl? What is protocol?
Got a picture or web site to get an idea of what it is your trying to do?
journeyman carpenter
ahhh didntt see the part about the ledger. in that case you have to remove the siding then install the ledger . then install j channel around the ledger and re install the siding
It would be much easier to just set posts to hold the arbor instead of attaching it to the house. In addition, if you do this, it would give you the option of removing the arbor at a future time if your tastes changed.
Roofmaster
I thought an arbor was a stand alone trellised arched entry into a garden area? What would something like this be doing above a garage door?
1 - 10 of 10 Posts
