1 - 8 of 8 Posts
Hello. I have this antique mirror that I would like to hang centered over my mantle but my studs aren't centered over the mantle.
I know there are different ways to do this, but what are your recommendations in hanging this heavy mirror centered over a mantle?
From hook to hook on back of mirror is 20".
· JOATMON
That is a cool mirror.....do you know any of it's history?
If it was me, and it's heavy....
I'd get a metal plate, say 6"w x 2"h. Put a screw in the center that sticks out for the cable to catch. put in 4 other holes evenly spaced. Put it on the wall where you want it...mark the wall thru the holes....install wall anchors.
It will actually be overkill.....but it won't come down.
I would think 1 large wall anchor would work. But with a mirror like that, who wants to take chances.
· JUSTA MEMBER
Find where the studs are.
Mark them, then install a cleat/ plate , made from a 1x4 or a metal one.
Bolt securely to the studs, then put a screw into the cleat centered wherever you want it.
As asked , what is the story behind this mirror, if you know it?
ED
The cable then becomes the weak link. Not sure if you have earthquakes in Texas. I have a heavy mirror with a back like this. Is there a way to support the bottom in case of earthquake? Even someone closing the garage door can knock something off the wall in some houses.
Or ddawg, did you mean 4 holes around the back of the mirror?
My mother bought this many years ago as an antique.
She also said that the knobs indicate the number of colonies, but this is all I know.
It's cool, it's wood and its heavy.
Thanks
I found similar ones. http://www.oneofakindantiques.com/p...ral-eagle-top-gold-leaf-bullseye-mirror-c1800
http://www.ebay.com/itm/18th-Century-Girandole-Gilt-Wood-Convex-Federal-Mirror-/272150270338
Range in price up to $4800! It may depend on if it's the original finish and if the mirror was changed. They mention bullseye ( convex) and a finish on the back of the mirror. http://www.merriam-webster.com/dictionary/eglomise
Thanks! So interesting.
1 - 8 of 8 Posts
