I'm trying to install an adjustable-depth 2-gang Smart Box for old work. I'm replacing a 1 gang box with this. The first time I tried installing it, after tightening the screws on the side, it pulled the box in about 1/8 or 1/4 inch on top from where I had wanted it, but the bottom stayed pretty much aligned. Then it was a nightmare trying to get the outlets looking good and aligned when the box was crooked. Now I'm starting over after filling the top old hole in the stud with wood glue and toothpicks.
What's the secret to minimize how far the Smart Box pulls in when you tighten the screws? How far does it usually pull in when you tighten the screws?
This is being installed in the middle of a wall, so I'm not able to clamp the box to a door jamb or anything, which I'm sure would help keep it in place while tightening.
