I have a 2004 dodge neon that hasnt been turned on in 2 years. What is all the checks i need to do and things i need to change out to get the car ready for a potential road trip?
basically, do a full maint. on it
oil change
plugs
leads
get the battery checked and if older than 5 years replace it
check your tires, over inflate by a couple of PSI and drive it around town for 10 clicks or so to put the round back in (IF you didn't store it with 40psi)
you could put a good fuel additive in, something like techron, but no need
do a couple of fuel tank changes
you should be good
if the brake fluid has not been changed, change it, it's hgroscopic and it should be changed out every 2 years
that will cost more than the value of the car, i wouldnt do anything except checking tires, putting new gas and drive it like that, the car value is almost 0 even if in perfect shape
I would be taking a really good look at the age and condition of the tires, especially if they have been sitting out in strong sunlight.
https://www.tirebuyer.com/education/how-to-determine-the-age-of-your-tires#
Air in the tires, change the oil, fresh gas, and drive it. Unless it was a POS before you parked it in which case all bets are off.
