How do you go about framing a wall so when its drywalled it has very few bumps in it or differences in height?
I know when you pick boards you are suppose to find the ones with the least twist and straight as you can on the front edge and side edge so you don't have bulges in you walls... then when you put the studs up you put the crowns all going one way... but even with this, I seem to have problems with drywall having some valleys or high spots in it... not major, say like an 1/8th an inch at most, but when you put stained trim on it stands out as a gap...
any tips, suggestions, or articles I can read to try to improve my skill?
also does putting construction adhesive on the studs before drywalling help any with the bumps to flatten out the low spots or anything? thanks
