I am having issues with the newly constructed home my family and I moved into November 2019.
My question is: What is the correct way to fix these issues?
Is a complete floorhttp://i.viglink.com/?key=34123deb0...&txt=<span>complete </span><span>floor</span> tear out required? That way the sub floor can be screwed down, island secured properly, then floor installed?
Please note - the builder has a long track record in the area (25 + years building homes) and uses the same subcontractors for many years.
- Moved into home November 2019
- Noticed floor bounce throughout home (ranch)
- Floor bounce caused kitchen island to bounce (picture T-Rex scene in Jurassic Parkhttp://i.viglink.com/?key=34123deb0...y&txt=<span>Jurassic </span><span>Park</span> with the water bouncing in a glass), duct work to squeak, and overall floor pops and squeaks
- Builder agreed to sister 30+ floor joists to remove floor bounce in February 2020 (not 100% successful but a noticeable improvement)
- Adding the joists caused the sub floor to shift which resulted in dips and high spots to be felt under the luxury vinyl plank floating floor when walking on it
- Flooringhttp://i.viglink.com/?key=34123deb0...Floor Pro Community&txt=<span>Flooring</span> subcontractor came to review in May 2020 and found handful of planks had broken locking mechanisms, but said high and low spots in floor is within specifications and will not be fixed
- Numerous other floor pops and squeaks developed as result of shifted sub floor
- I was told it's normal and house is settling, lumber is drying out, etc.
- 3 other contractors came out to review moving kitchen islandhttp://i.viglink.com/?key=34123deb0...&txt=<span>kitchen </span><span>island</span> and all said it is secured to the cleats properly, but the sub floor is not secured to the joists properly.
- Builder suggested adding legs to overhang of island. Temporary 2x4 legs were rigged up to test for improvement. While a minor improvement was there with the legs, it is not the look we wanted our kitchen islandhttp://i.viglink.com/?key=34123deb0...&txt=<span>kitchen </span><span>island</span> to have. If it was a complete fix, we could live with it, but for a minor improvement, we don't want the legs there.
- Floor throughout house sounds like walking on peanut shells or cracking ice. Someone said it sounds like rice krispies are crackling under the floor
- I contacted manufacturer and described sound
- They said sounds like improper sub floor prep prior to installation (could be debris under floor)
- Flooring contractor and builder said it is normal for floating floor to make noise
