soaker tub and backsplash, kitchen backsplash, Var fixes around the house.
I am going to have to remove some floor and replace it. I am not sure this is a sound plan and am looking for some extra advice please.
I Have to get in to do a little pipe work (minor) and replace the floor and underlying gypsum board (I am guessing fire retardant.)
There are two web joists (one on each side of my cut.) Maybe @12" apart)
I could try to cut the floor to 1/2 of the width of the web joists on each side.... (@13" x 12"-16") and use it to support the patch which probably wont work to well.
Instead: I thought to screw two 2 - 2" x 8" boards on each side of the cut to the web joists and use that to support the patch. This would add much more support. I could take it one step further and add 2 2" x 4"s to the other sides for extra support. (maybe even use web joist hangars.)
When done, there will be a dreamline acrylic shower pan installed over it seated in mortar.
Does this sound like a good plan?
I have attached pictures.
