Basement lighting I have flourescent fixtures plugged into outlets. the outlets are mounted in the 4" square boxes on the joists. two single switches on wall where each switch controlled an outlet. I replaced an outlet and then replaced the two single switches with one double switch.
Below is the wiring how do I complete this so that the bottom switch controls the right outlet and the top switch control the left outlet? Thanks
