1 - 6 of 6 Posts
I just pulled up some old carpet in my living room to replace with tile, and noticed that I have a floor joist that has risen and caused a crackline in the subfloor. It is not a bad spot and was not even noticable when the carpet was down, but I'm concerned that the tiles along this ridge will not settle correctly.
How do I go about fixing a raised floor joist? I'm more use to a sagging joist where all you need to do is add a lift jack in the crawl space, but have not delt with a joist board that has risen.
Any and all advise will be very much appreciated!! Thanks in advance!
2 threads on same issue merged
Banned
Is there a basement below ?
Is the house sitting on piers ?
I'd be more concerned that whatever is causing this will continue
An older house we looked at had the same issue - but worse
It was a post in the basement that was being forced up
Discussion Starter #4
The foundation is a crawl space and is a standard floor system. I have not gone down and check this area yet, but I believe it should be accessible. The house was built in 1969.
Any advice on how to determine what is causing this rise?
Retired Moderator
If it is just a bowed joist--Do as Kwikfishron suggested--open the subfloor to expose the joist and flatten it out with a skillsaw or power plane.
If something is pushing it up--post a picture.
Registered User
You do know to add underlayment for tile over your subfloor............. Could be a high crown, if the only one next to normal ones. Use a straight-edge or level to determine the problem, get back to us for the solution.......
Be safe, Gary
1 - 6 of 6 Posts
