1 - 19 of 19 Posts
Hi, so I am working on a basement wall and the double header that was used is short of the inside stud wall by roughly 1/4 inch. I don't have 1/4 inch drywall on hand, is that what is normally used to fill this space in? Could I used cedar shims?
retired framer
Anythings that fits, if your walls had been 2x6 the space would have been 2" deep and it is left for insulation.
Discussion Starter #4
Thanks Neil, I'll see if the shims work. If I used them I feel the support will be a bit flimsy.
retired framer
I see the have used plywood but not matched it to the studs. You do want to at least make the bottom match. Plywood, or rip the edge off a 2x4 if just for the bottom.
Discussion Starter #6
I actually added that 3/4 plywood filler when I put in the new window and then caulked it with foam before seeing that it didn't match up with the stud. But its no big deal as I am going to go with drywall return with no case on the windows.
Well there's your problem.... You should have used 1/2" foam board and then 1/2" plywood on the exterior to bring it level. :devil3:
Or, next time you are at a big box store, check to see of there are any damage sheets of luan or 1/4" drywall and you can usually get them for a steal. And then you would have them around.
At Lowe's check around the panel saw for any left over cut sheets. At my local store they are free. I always check and I have gotten some real good product. One time, I got some 2x4 left over cuts of 1/2" oak furniture grade plywood.
Discussion Starter #8
I might have not explained that well. I put a new window in and it had a 3/4 space above so I added a 3/4 piece of plywood between the top of the window and the original header. The original header used is flush on the outside with the plywood but 1/4-1/2 short on the inside. So you are saying to add a 1/2 piece of foam in that gap I have, which makes sense. That would give the header just a bit of insulation right?
retired framer
If the outside wall has a header over the window, you didn't need to add one to the inside wall.:wink2:
I thought you added it to the face of the header, not the underside. As Rosanne Rosannadanna used to say: "Never mind"
This is one reason why headers should have 1/2" plywood sandwiched between the 2 by's.
Another reason is it provides more strength to the header.
Add a 1/2" of either plywood, drywall, etc..
Why didn't you install the ceiling first.?
retired framer
That is the inside wall of a basement, no need for a header.
Don't you usually have a sill under a header.
I'm not there so I will not pretend to know the reason for the header.
I just know how headers are made.
Also if you look at the top plate you will see the 1/2" difference.
Unless there's going to be a drop ceiling, the ceiling should have been first.
retired framer
Yes there is some confusion there, if he stopped the top plate to make room for the header then a full filler would have been needed anyway. the bottom plywood was just measuring to the header instead of the stud.
Just my opinion.
Add a 1/2" piece of plywood to the header and drywall it.
Miller time.
Discussion Starter #18
Ended up using some long cedar shims in a few spots, the space was a hair under 1/2". Then used metal bead for the corners and spackled and painted. Ideally when the header was built the builder would have used a thin piece of foam in-between, but this was made before energy codes.
retired framer
Down there it is common to put the plywood between, foam wouldn't do it because it needs to nailed tight to make a beam. We never do it because often build with wet headers, they shrink and the plywood between makes the 2x split at the nails.
1 - 19 of 19 Posts
