1 - 7 of 7 Posts
I bought this stuff at lowes that eliminates brush marks to help me paint a door and jam. I think it's called "Flotall" or something like that.
On the first couple coats, I forgot to shake the bottle, so I still got brush marks. Can I just sand the first coats down a little with a 200 grit sanding pad and put a couple good coats on?
The paint is interior latex semi-gloss.
Registered User
Floetrol is a paint additive that helps the brush strokes lay down. It won't entirely eliminate them but it does help. Penetrol does the same thing for oil-based paints. I presume the Floetrol was mixed into your paint at the correct ratio? Not clear on what didn't get shaken???
You can knock down the high spots on the existing coat with some 150 or 220 grit sandpaper and then re-coat.
Discussion Starter #3
I forgot to shake the Floetrol before I mixed it with the paint. So only the clear thick stuff got mixed with the paint.
Coatings Nerd
Floetrol is an extender...it helps the paint stay wet longer giving it more time to level out. Just dont add too much or the paint will stay soft and possibly sticky.
Discussion Starter #6
I'm just concerned that I may have messed up the bottle of Floetrol because I didn't shake it up when I used it for the initial couple coats of paint. When I poured it into the first batch of paint, only the thicker clear stuff came out of the bottle, leaving the thinner white material in the bottle. Can I still use the Bottle of Floetroll I have?
1 - 7 of 7 Posts
