how to cut roll roofing properly around outside corner?
1420 Views 6 Replies 6 Participants Last post by  carpdad
2
my roof is totally jacked up. It was built improperly.
attached photo shows the outside corner in a cricket area which needs to be reroofed properly.
I can't imagine how to cut the roll roofing in the corner so that it does not leak at the cut.
How do you make the outside corner leak proof?
I'm cutting up pieces of blank paper trying to imagine how to lay the sheet down at that corner
1 - 7 of 7 Posts
There are stick down rubber products they will stretch around that corner without cutting.
but the cap sheet is not flexible like that
You just have to imagine where the water is moving on the roof to see you need more crickets.
Good thing you don't get snow. What a clusterf***. Don't know what you mean by rolled roofing but that is a basic flashing detail for any flat roofer.
You need a metal flashing like the image. Best is copper sheet and all joints soldered. But next best would be aluminum held together with rivets and joints covered with eternabond tape. A good caulk (I use osi quad) could last a while but probably the joint will crack and open. This flashing must go under the stucco. Under the step flashing on both sloped parts and over the valley flashing downhill.
Temporary fix would be a tarp, not a roll roofing. Big enough tarp to cover both sides of the slopes. If you don't cover all of the roof there, corner flashing that is installed over the step flashings will leak.
Search for images and videos of roof flashing. Chimney and dormer flashings apply to your situation. All flashings overlap and if a low slope, joints must be sealed or caulked or other means against water traveling sideways and sometimes, could travel up slope if a valley or such.
1 - 7 of 7 Posts
