Hi everyone, new...here i have checked out your blogs for months now, and finally decided to join. OK my question is, i have been redoing my kitchen for the past month 1/2...awful trouble painting my cabinets....long story, but anyway, the main issue now is i went w/ semi-gloss paint, which i love the sheen, but now everywhere i have caulked looks awful, i tried to sand out the caulk but it seems to gumm up....any suggestions? Desperate help, just want to get finished!!
· Remodeling Contractor
You will need to remove the caulking. What type did you use and where? When applying the cauling again, tape off both edges and tool the caulking with a metal spoon dipped in denatured alcohol to give a perfect smooth joint.
When we caulk we always use a wet rag to remove any edges. Its difficult to remove these edges once they have been painted over. You can try a very sharp scraper. Remove the caulk and sand area smooth. Just remember after you caulk an open joint, smooth with finger, then wipe with a wet rag removing excess caulk. Good luck.
