So I'm doing a remodel...turning an area that was a hallway and pantry and laundry area into a mudroom. The floors are out of level so I tore up the plywood and found that the first 3 feet of the entire area is built over the garage slab. So from the man door at the garage wall to about 3ft in is all over slab, this stops at the basement foundation and the remaining room sits over the basement. The flooring that sits in this area was always cold and you could always tell it was a cooler area in the house. There is wood framing between flooring and slab and the gap from floor to slab is roughly one foot. Currently they have insulation batts stapled to the joists but they obviously aren't doing much.
What's the best way to insulate between the slab and joists/subfloor to prevent any moisture issues and keep that cold air out? I don't want to create problems. I can try to attach photos once I get to working on it again.
Thanks.
Thanks.
