Hello,
I posted here a good while ago regarding pouring a foundation slab to build a wood fired oven.
Well, meanwhile I've been busy building the oven itself. It's been fun.
Now that the oven is almost done, I want to make a small pergola style single pitch roof structure to protect the oven from wind and weather. Single pitch to make it easy to get the oven chimney through the roof. Gable flashing is super expensive around here and I haven't much experience with masonry, although I built a deck last year.
I'm sharing the very basic attached pictures of the oven and my idea for roof.
I have some repurposed 4 by 4 posts which I want to fasten to the base slab. Higher in front than in back so water can drain off the roof. My idea is to cut half of the 4 by 4 off up to, maybe 10-12 inches, then put that notch over the edge of the slab and drill 2 expanding concrete anchors through the side of the posts and into the CMUs. The CMUs core is filled with concrete so should be enough substance to receive the expanding bolts. Then where the notch goes over the edge of the slab I would put a heavy duty stainless bracket on the inside of the post to fasten it to the surface of the slab.
Does this make sense, and would it be strong enough to hold a relatively light pergola style of wooden roof structure? Or are there any specific concerns or ideas I should take into account before going ahead with this idea?
Thanks a lot in advance for any inputs from experienced people here.
Best,
Simon
Best,
Simon
