1 - 10 of 10 Posts
i have 2 OLD thermostats running off batteries.
one of them controls the heating in the basement with only 2 wires:
Temperature Font Gas Rectangle Measuring instrument
the 2nd one controls the cooler on the roof with 4 wires as seen here:
Gadget Rectangle Material property Cameras & optics Gas
Font Gas Technology Electronic device Circuit component
how do i control both of them into the new thermostat, TRANE 14942771? i just bought a 24V AC transformer that has 2 wires coming out.
so having a total of 8 wires, where should the wires go to?
Font Machine Number Temperature Gas
You’ll need a diff thermostat, something with separate RC and RH terminals. What you have can be done but you’ll need isolation relays with that thermostat.
i think i see what you mean now. my Trane does not have a jumper. looking at this new wifi Honeywell, there's a jumper between R and Rh that can easily be removed
i swapped for this Honeywell RTH9585WF1004. i am able to have Rc and RH by removing the jumper between them, according to the manual.
these are the pins for it:
Font Rectangle Parallel Number Pattern
please advise on how i can wire them. thank you so much!
these are the 4 pins for cooling system:
Circuit component Font Gas Electronic component Technology
these are the 2 pins for heating
Wood Jaw Electrical wiring Interior design Floor
they go to a controller in the basement labeled TV and T
Hood Motor vehicle Steering wheel Automotive exterior Gas
Administrator
That would be the correct way to wire it up.
Reactions: supers05
1 - 10 of 10 Posts
