Good morning all,
I need some suggestions on a project that I've been working on. I'm closing off a quarter of my basement for a playroom for the rugrat. When we bought the house, one wall was already in place as a divider for the laundry area. I've already framed the second wall and run the electrical (wires only, nothing is hooked up). I also have painted the rafters white to brighten up the space. The wall I framed runs perpendicular to the joists, so I'm left with open cavities above the top plate of the wall. I'm looking for suggestions on how to close off that space. I do not want to install a ceiling of any sort. I don't need anything fancy and definitely need something inexpensive, but don't want it to look like junk. I debated stapling the rolled batt insulation with the paper backing. I think that'll look like junk. I've also though of running leftover drywall up there or cutting foam board insulation panels to fit and painting them. The new room is heated, but we left the cinder walls exposed, so there will be some temperature fluctuation. I mention this because it's not necessary that the solution be airtight. Although I wouldn't mind that.
Let the brainstorming begin.
Thank you in advance!
