1 - 11 of 11 Posts
· JUSTA MEMBER
Is the post exposed on top?
The best that I ever was able to do was form the coil stock into a square tube, slide it down over the 4X4 and put the single seam on the least visible side.
Depending on how the post is usually viewed then I put the seams away from the viewing direction.
ED
· From Philadelphia
Ahhh, I should have mentioned in my original post that the posts are already in place on a front porch, so the bottom is attached to the ground and a beam then roof sits on the top of the posts. So unfortunately there is no way to slide it down over the 4x4 :-/
· A "Handy Husband"
Not aluminum but this is how I installed a vinyl post wrap on a porch post. Ripped down the middle of one side on my table saw. Forced the post cover open and around the porch post. Closed the seam with a strip of vinyl lattice secured with white aluminum screws.
Reactions: de-nagorg
If these are pressure treated post then forget about using aluminum to wrap them.
Even the box it comes in says not to do it.
Pressure treated is treated with copper and in a few years the finish will bubble up on the coil stock.
Lot's of company's sell snap on post wraps, not cheap but will hold up and look a whole lot better.
Reactions: rjniles
Not true. Aluminum can be used on pressure treated post but must be wrapped first with 3 or 4 mil house wrap, then the aluminum can be used. This prevents any corrosion from occurring. However, Its important that the post be allowed to completely dry first ( usually 8 weeks) before applying.
I bend a piece to cover 3 sides and install it. Then I bend a cap for the last side (usually the front), returning 3/4” to 1” over the sides with its edges hemmed over to the inside. Drill through the aluminum to avoid dents and nail it through the hemmed sides. I was called to replace one without hemmed over edges where someone cut their hand on the exposed raw edge. From then on, I always hemmed the edges.
1 - 11 of 11 Posts
