1 - 13 of 13 Posts
im thinking of building one.never built one. im jus wondering how far apart do i put the 2 x 4's from each other. this is gonna b built on the side of the trailer i live in. what roofing materials can i use? i was looking at lowes, the corregated roof panels or fibergalss. any other options?
What you can do will depend on where you live. The construction mentioned will not work in northern regions with a snow load.
Ron
You talking to me?
you are building a "lean to" and I doubt it will be acceptable to attach it to a trailer. It will most likely be required to be self supporting and you should not use 2X4 material for the roof rafters unless the width is quite short and there is no snow, ever, where you live.
You should speak with your building department. They are who controls what can and cannot be built in your area.
Crown
anything pretty much goes in this sorry a** nasty trailerpark....thanx for all responses. what should i use besides 2 x 4? it hardly snows out here. whats crown the lumber mean?
Means all lumber has a bow to it, when you build your room or wall take each piece of lumber look down the length and you will see a bow, make an arrow on the side facing up or bowed up.
Now when you build your roof face all crowns (high sides) up. When you build your walls all crowns out. That way all your floors, walls, roof, are straight when you look down them or go to sheet rock them.
Not so new
I dont think it matters ....at this point the OP needs more help than figuring out which way his stick bends. At this point he doesnt posess the building knowledge to erect a structure that people walk under. But I could be wrong so here goes......Nap may be right about the free standing method but you wont know unless you call your building department. That said use no less than 2x6 rafters at 24"oc supported by the required number of 4x4 posts set on and attached to concrete footers to below frost line if for nothing else than to hold it down when the wind blows. Run purlins accross the tops of the rafters at 24"oc and screw down the roofing material. I think you still need 3/12 pitch even with a steel roof. I'd stay away from the fiberglass ones but its a matter of choice. You could also plywood the deck and use roll roofing. Probably a more economical choice. You didnt say where you where so we really dont know how much snow is "hardly any". Maybe a picture of the site would get some more feedback. Good luck with your project.
How much construction experience do you have? If you can't build this correctly, it will collapse, possibly cause injury or worse.
A cloth car cover might be a prudent alternative.
Ron
Discussion Starter · #13 · (Edited)
ya ya get him get him! anyways this is kind of what im thinkin. its not gonna b that long though. dont look like 2 x 4 on the side but on the roof it does. this ones attached to the house. ill try to get a pic of my place.
1 - 13 of 13 Posts
