41 - 45 of 45 Posts
Super Moderator
Discussion Starter · #41 ·
When you are doing a bevel edge, does it go on all edges...specifically, would it go on the edge beside the stove? Can you post a picture of what the counter edges look like when using a bevel edge beside he stove if you have one?
I am tempted to use the crescent edge on both edges. This will eliminate the exposed mdf, but will result in a bit of a gap between the stove and counter.
Here is a link showing the bevel edge and the crescent edging:
http://www.wilsonart.com/homeowners/laminates/edge-options
I agree with you, using the crescent edge against the stove and front would solve a few problems.
Renovating My Land Yacht
Couple of Q's if I may.
Where to buy the laminate sheets other than big box? My assumption is I do not want vertical grade as that is thinner correct?
I was planning on using MDF as the substrate and want to seal it as much as I can prior to putting the laminate on. I have heard of using the glue water mix, will this work for the underside? (looking to just add a layer from the front underside edge back for a few inches to protect from drips running over the front of the counter back towards the cabinets)
Super Moderator
Discussion Starter · #43 ·
You are right, you do not want vertical grade it is paper thin. MDF will be fine but I would seal all the bottom just as a precaution. MDF will swell especially over the dishwasher because steam can escape the DW. I like TightBond III because it is water proof but a good enamel paint will work also. Don't use any sealer where you will apply the HPL.
If you can find a cabinet supply, they will have HPL, some lumber companies will also but the cabinet supply will have way more. Is there a reason you don't want to buy HPL from the big box stores? They don't have a huge selection but maybe they could order you some.
There are places online that will ship to you.
Thanks Jim...so today I did a lil shopping and it looks like I am stuck with one online option. Looked at the big box and funnily enough the 5 cabinet supply companies and the big box all get their counters/laminate from a factory just down the road....and unfortunately they are all 2 weeks out. Guess I am going to have some temp plywood in my future :p
Super Moderator
Discussion Starter · #45 ·
Here is an online supply who will have just about any HPL you could want. They do ship.
http://www.baersupply.com/baer/servlet/CyberVendor/category/C1257687/catalog/?ShowAllGroups=True
These are one of the suppliers I used when I was in business.
41 - 45 of 45 Posts
