Hello to all,
I recently had a lightening hit but didn't know if it was an errant or direct hit. I now think I found the main source. Pic 1
Pic 2 is the light switch that blew up and is right under the roof of pic 1. The hole in the galvanized metal roof & charred wiring & 2x4 fried both the switch & the porcelain light fixture that the L-switch operates. In the next room of the shed where the junction box is located and that feeds the blown fixtures, has 2 more light switches and 4 light fixtures. All of them still work fine.
The junction box is fed by 150ft of undergrd wiring in conduit buried 16" and runs to a 100amp garage panel. The garage panel is fed by the main house panel. At the time of the hit, I had the breaker turned off bc that same light switch was blown b4 when an oak tree next to the shed was hit (6-8 yrs ago),
The main house panel had 4 single pole breakers flipped, but no double poles. A 110 outlet was fried along w an adapter converting the 2 plug out to a 3 plug.
Too conclude, I know w lightening all bets are off, but how is the best way to ground the building that's taken 2 hits? I have a ground rod hooked to panel in garage. I was thinking of putting lightening rods on shed and linking it to new grounding rods. Any suggestions on how to best go?
In another thread, I was seeking advice in expanding house panel from 100 to 200amp and installs SPD bc current panel is maxed. Nothing is going to stop lightening, but just trying to put better odds on my side that's realistic and cost effective. I'm cking w SBECoop if they can install SPD on meter.
Finally, if a circuit/breaker is turned off at the area it feeds and that area is hit by lightening, can it still jump the breaker and travel up stream?
Thanks
tstex
Thanks
tstex
