I'm looking to knock out the wall shown in the picture. I was told by my structural engineer that this isn't really a load bearing wall, as it's not supporting the floor upstairs, however is still supporting the "wall" immediately above it on the 2nd floor. Therefore I will still need to add a beam if I wish to knock out this wall.
On the image, the red arrows shown the orientation of ceiling joists.
As I understand, to add a temporary support wall for typical load-bearing wall (where joist are perpendicular to the wall), one would build temporary supports parallel to the wall, and on both sides. However, this wall, on one side (kitchen), the joists are parallel to this wall, while on the other side is an open ceiling. For this situation, how would I add a temporary support there in order to install a beam so I can open up this wall?
Directly above the doorway (on the side with the open ceiling), there is a floor above it (2nd floor lobby), I guess I can add a typical temporary support there parallel to the wall while installing a beam spaning all the way across (shown in black on image)?
Thanks all!
Thanks all!
