I am currently researching, learning, and planning to build laminate countertops. I took some rough measurements of my current tile countertop. They aren't precise, and could be 1/2 to an inch off. Just something to work with for now.
I've only seen sanded plywood come in 4x8 sheets, though I have not looked around too much yet. If I could find a 10ft sheet, that would be perfect.
So, if I use the 8ft sheets, how should I accomodate for the extra foot that I need? What would be the best route to go as for adding the extra foot?
Should I add it on the left side here:
Or put it on the right side? If I go with the right side, what would be the best way of doing that?
The very left side will have a dishwasher under it. The top and far right side will be at a wall. The sink is in the direct center.
I can get the laminate in 10ft lengths, so I am thinking that once I have the countertop built, I can put the laminate over the whole thing seamlessly.
Any thoughts, suggestions, tips, or idea's?
