So I had the misfortune of having to install a new water heater for my house. The old one had a slow but steadily increasing leak from the bottom of the tank and was 12+ years old. I turned off the cold water supply, opened a hot water valve at a few sinks upstairs and let it drain.
I started disassembling and noticed this:
What's wrong with the order of union to shutoff? Yep, Union THEN shutoff. The only other shutoff for the house was the whole-house shutoff. If it was just me it wouldn't be a big deal, but I have 3 kids and a wife with a bladder the size of a pea (pun intended).
The other issue which wasn't a HUGE deal, but still annoying is they didn't have a shutoff on the hot water side. While I drained the plumbing, if my wife turned the water on with one of those lever faucets (kitchen sink for instance), a slow trickle would flow down.
I wound up having to turn off the whole house, cram bread up the cold spout, resolder the various bits to move the shutoff to ABOVE the union and then continue on.
I also moved from a 40 gallon to a 50 gallon tank so some rework of pipe lengths was in order.
The humor in this? After I moved the shutoff, I had my daughter hold a piece of hose up to the union to help redirect the water when I turned the house water back on (to blow out the bread) It didn't work quite that well or she didn't expect the pressure to be so severe and she got a soggy bread explosion shower! :jester: Glad I decided to turn the water on versus holding the hose! :whistling2:
