Generally final inspection for electrical is done with the drywall in place and cover plates able to be put on the outlet boxes if not already put on (In the latter case the inspector may or may not take off a cover here and there to see that the wires were screwed or backstabbed correctly). The system must be ready to be energized (if not already energized).
Drywall does not need to be finished (taped, mudded, painted).
All this assumes that you had a rough inspection with no drywall or insulation and all the strung Romex cables visible.
