1 - 9 of 9 Posts
Building an addition and it looks some of the 12 ft wide (16 foot long) joists have only 1 inch sitting on the Sill (or upstairs wall). There is a joist running perpendicular which appears the joists are nailed into. Is it ok with only 1 inch of a 16 foot span is sitting on the plate but nailed into another 6 foot x 12 inch high joist that is also sitting on the Sill plate.
Also, which is better for a 16 foot joist span, solid wood blocking between joists or cross bracing at center (8 feet)?
Thanks for any help.
· Registered User
2 inches
Been framing for 15 years, have heard 2" bearing is the standard since year one. 3 1/2 inch plate, rim takes up 1 1/2, leaves 2 for the joists. The span isn't relevant.
Hang those.
Or if the sill is on block or concrete and there is room, add more sill under the joists. (pressure treated).
· Registered User
As VaVia said, you should have 2" there, what happened?
In the UBC, '76, '83 and 2003, (ones I bought new), the minimum bearing on wood is 1-1/2", UBC 2320.8.2.
Be safe, G
When I do additions, I use a 2x6" sill plate, so you would have 4" bearing on the plate.
Why would you use a 2x4 as a sill plate. It seems skimpy to me to have the house bearing down on 2" of wood.
Ron
· Registered User
Bearing's been pretty well covered.
As for the question about bridging/blocking...
Cross-bridging or solid blocking at mid-span will work equally well. The nice thing with bridging is that you can still run plumbing and electrical through it.
· Mold!! Let's kill it!
Ron
OP said it's a second floor joist. There are millions of homes with second floor joists bearing on 2" of top plate in the exterior walls. Sounds like some-one doubled the ring joist in a short area. That doesn't leave enough bearing. I'd use some joist hangers in that short span.
I guess I should pay closer attention to the details.
Ron
1 - 9 of 9 Posts
