Hi, it's me again;
I have been looking at all of the plumbing in the basement after having to replace a pretty good amount of old pipe after a leak last Saturday.
I am looking in the furnace room, where the water heater is also located.
It's a gas unit, 10yrs old. No problems with it yet, but I'm starting to think of ways I can improve the system when eventually it does need replacement.
One thing I am thinking of is removing all of the 1/2" pipe to the hot water heater, on both the cold and hot sides and replacing with 3/4".
Most of the major plumbing is already 3/4", but around the WH, it drops down to 1/2" copper. The fittings on the WH are 3/4".
How much of an improvement in hot water supply would I see by replaceing the 1/2" pipe with 3/4", including several 90 ells, and a couple of Tees.
There is approximately 4ft of 1/2" pipe in the cold supply to the WH, and about 3ft in the output side.
I'm thinking that perhaps there would be less of a decrease in hot water supply (shower suddenly turning cold) when the washing machine is using hot water for instance.
There seems to be less of a problem when cold water is used elsewhere in the house during a shower downstairs.
I'm also thinking of replacing the bath/shower faucet with a pressure regulating type.
Thanks for your advice/suggestions
FW
FW
