I'm sure the default answer here is 0%, but hear me out...
I just replaced the hose on my gas dryer. The original was removed a few months ago, and we used a small cap to seal up the gas until we could replace the hose. Thus far, we've had no issues with gas smell or leaks.
A few days ago, we removed the cap and tried replacing it with a standard universal gas dryer hose kit (smaller/thinner than the previous). We had gas hissing out as well as the smell filling the upstairs. We finally took it off and just re-capped it.
Today we tried again, using the larger "pro" kit, that is the exact same size that was there before. I was able to stop any noticeable gas leaks or hissing, but we can't seem to get rid of this very faint gas smell that still resides.
Now let me be clear. We have tried EVERYTHING. We worked all day swapping out every different size and type adapter for the hose and the gas line, we used pipe thread (from small amounts to lots), and we made sure all the nuts/fittings we're as tight as humanly possible (using a larger pair of players to where they could not possibly tight another inch, almost to the point of stripping). And again, the hose is the largest they had.
You can't smell gas in the upstairs at all anymore, or even if you just stand over the pipe. You have to get right down to the fitting and sniff to get any kind of whiff. We also did the soap bubble test, which it passed.
I'd say it's 98% sealed up, with only the faintest hint left if you really get down close to the pipe. But there is virtually nothing else we know to do, and I never checked to see if this was normal from the previous installation.
So is this acceptable/safe? The other dryer hose sat like this for years apparently.
